2004 Ford Explorer
ERNIE LUTFY
  • 2004 FORD EXPLORER
  • 6 CYL
  • AWD
  • 56,400 MILES
When decillerating from about 40 or 50 MPH I hear a thumping sound and maybe wheel bounce from front end. It sounds like a rotational frequency noise.
It seems to get worse after the car warms up. I also notice this problem if I shift the car into neutral at these speeds
to try to disengage the powertrain.
It does not happen when I accelerate. Can anyone give me advise?
Tuesday, January 26th, 2010 AT 7:01 AM
  • 109,885 POSTS
Check tires to make sure there are no shifted belts. Also, does the sound change when making turns?
Tuesday, January 26th, 2010 AT 7:21 AM
ERNIE LUTFY
The sound does not change when turning. As I stated, it even make the thump noice, and feels like a bubble in a tire, when I shift to neutral. Does the powertrain disengage when I go to neutral at 45 MPH? I cannot see a blemish in the tire.
Tuesday, January 26th, 2010 AT 12:00 PM
