2004 Ford Explorer
NMINGO
  • 2004 FORD EXPLORER
  • 6 CYL
  • 44,500 MILES
I have recurring thump thump thump as the wheels rotate. I can feel the thump in the sterring wheel. The mechaic keeps telling me its the brakes that are making the car make the noise however when I apply the brakes the noise stops. What could be the problem?
Sunday, June 21st, 2009 AT 4:33 PM
BUDDYCRAIGG
  • 2,262 POSTS
Sounds like a brake problem to me too.
What parts does your mechanic suggest be replaced?
Sunday, June 21st, 2009 AT 5:31 PM
NMINGO
He has already machined the rotors and he saying that the brake pads would have to be replaced to stop the noise. He says the pads are good but because sat up so long it may have caused some 'dry rot"
Sunday, June 21st, 2009 AT 5:40 PM
BUDDYCRAIGG
  • 2,262 POSTS
Missed that bit of information in your first post.
Now I suspect a tire with a slipped belt, bent rim, or failing bearing.
Do you get a vibration at highway speeds?
The Thump, thump thump in the steering wheel.
Is there a noise that goes along with it?
Does the steering wheel rock slightly with the thump?
About the brake noise, is it a squealing or scraping sound that stops when you step on the brakes?
Sunday, June 21st, 2009 AT 6:05 PM
NMINGO
Thats just it, there is no noise when braking accept for a squeaking noise coming from the back brakes.
Yes slight vibration at high speeds, yes the steering wheel does have vibration in it when the the thumps are heard. If I go real slow the thumps are slow but they are more like a grinding thump.
Sunday, June 21st, 2009 AT 6:18 PM
BUDDYCRAIGG
  • 2,262 POSTS
Next thing to do is jack the front end up and support it with jack stands.
Then rotate the wheels by hand, feeling and listening for a noise or a dragging.
Sunday, June 21st, 2009 AT 6:57 PM
