2003 Ford Explorer windshield washer in cold weather
JOHN1761
Electrical problem
2003 Ford Explorer 6 cyl Four Wheel Drive Automatic
My windshield washer won't spray cleaner in cold weather 20-5 deg F . I use fluid ranted to -20 deg F. Is this a common problem with this model. The sprayers are in the hood .Could this be the problem ?
Jan 17, 2009 at 11:34 PM
BMRFIXIT
  • 19,053 POSTS
Need to replace the spray heads at the hood they shouldn’t be much money
and if still do not work
the pump coming on its the fluid
try and check if your local part store sell W/ W deicer
u can add to the fluid
Jan 18, 2009 at 12:33 AM
