2003 Ford Explorer weird noises
140,000 MILES • 6 CYL • 2WD • AUTOMATIC
POCOLACHRISTIAN
  • 62 POSTS
I have a 03 ford explorer and I noticed when i accelerate i hear a noise in the what sounds like the rear end kinda siren type noise. When i let off gas and coast to a stop or brake to a stop it sound like a siren winding down any ideas thank you
Nov 1, 2010 at 11:56 AM
  • 110,251 POSTS
Have you checked wheel bearings, pinion bearing and trans output shaft bearing?
Nov 1, 2010 at 1:05 PM
POCOLACHRISTIAN
  • 62 POSTS
I got the rear end rebuilt about 4 months ago so it shouldn't be that. How do you check wheel bearings or the trans outuput shaft.
Nov 2, 2010 at 1:24 AM
  • 110,251 POSTS
Basically, you need to check for excessive play in the component.
Nov 2, 2010 at 3:13 AM
