Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Explorer
Drivetrain
Transmission
Symptoms
Slip
2003 Ford Explorer transmission slipping
2003 FORD EXPLORER
52,000 MILES • V8 • 4WD • AUTOMATIC
DAVE KNOECHELMAN
MEMBER
1 POST
trasnsmission slipping when cold or sits for hour or two just changed filter and fluid no problem before it was changed.
Dec 4, 2008 at 7:14 AM
Experienced Mechanic
Hi:
It sounds like the clutch plates are bad. Most likely it will require a general overhaul.
Dec 9, 2008 at 1:00 PM
Add image or video
Ask a new question
Engine won't start
Check engine light
