2003 Ford Explorer Transmission Shutters when going into Ov
55,000 MILES • 6 CYL • 4WD • AUTOMATIC
PAULSKIYA
Once my transmission warms up, it shutters when it shifts into overdrive at highway speeds. It feels like driving over a small series of speed bumps. All other gears work great. When driving at slower speed the shutter isn't noticed. The fluid was changed and filter replaced, but that did not help. Is there an overdrive soleniod that is getting weak when it warms up? How easy is it to replace? I see this is a common problem with Explorers. Please help before it turns into an Exploder!
Apr 2, 2008 at 5:35 PM
FLEXY5
  • 512 POSTS
The concern appears to be the overdrive, however, the actual problem may be the torque converter. If you try turning off the overdrive, does it still do it? Most often, when the overdrive goes out, it simply fails to engage. The most common shudder from Ford transmissions is the torque converter. Unfortunately, the solenoid isn't usually the problem, but the torqe converter itself. Try turning the overdrive off and see if it still does it. Post back with an answer and we'll go from there.
Apr 17, 2008 at 3:23 PM
PAULSKIYA
It still does it when overdrive is off. I appears that it doesn't do it all the time, only under heavy loads. Would low, or overservice fluid cause this? When it's cold it doesn't do it.
Apr 29, 2008 at 2:36 AM
FLEXY5
  • 512 POSTS
It is possible that low fluid level could cause this concern. The shudder is the clutch inside the torque converter. The computer is commanding a partial lock-up, or a gradual lock-up. Rather than the clutch being on or off, they now are varying in percentage they are engaged. The most common failure is the clutch itself. It shouldn't fail with only 55000 miles, but I have seen them fail even sooner than that, so overservicing should not be an issue as long as the correct fluid is being put back in, that being mercon 5. The reason it doesn't do it when it is cold is partially due to computer strategy, but also because the fluid is thicker and therefore tends to do a better job of lubricating and pressurizing.
Apr 30, 2008 at 2:19 PM
