2003 Ford Explorer transmission lines
2003 FORD EXPLORER
140,000 MILES • V8 • 4WD • AUTOMATIC
BRANROCK
how does transmission lines hook to the radiator.
how do you put in transmission fluid
Feb 26, 2010 at 6:27 PM
  • 110,194 POSTS
THe trans is filled throught the dip stick tube. As far as connecting it to the radiator, some have a quick connect, some bolt, and some clamp. I would have to see it to know what type you have.
Mar 1, 2010 at 8:10 AM
P RINDGE
  • 9 POSTS
My 03 Explorer doesn't have a dipstick or a level sensor/indicator. It is filled from underneath through the pan with a special tool. Fill it until it overflows. Ford will do it for $45 (a quote I declined)
Phil
Mar 5, 2010 at 12:04 PM
