Transmission problem
2003 Ford Explorer 6 cyl Four Wheel Drive Automatic 138k miles
my tranny has been slipping out of overdrive and im trying to add lucas tranny fix and cant seem to figure out where to add the fluid at?
Sunday, January 24th, 2010 AT 10:56 AM
MECHANIC
Transmission fluid is added through the transmission's dipstick tube.
SPONSORED LINKS
Tuesday, January 26th, 2010 AT 8:00 AM
TRANSMAN1
MEMBER
If you have the 5r55E transmission you have no fill tube it is done from under the car and is real difficult with out a way of pumping it into transmission. The fill hole is the small allen head plug in the bottom of the trans oil pan that looks like it would be a drain plug.
