2003 Ford Explorer tire size
92,000 MILES • 6 CYL • 4WD • AUTOMATIC
JAMESMC
I have two different size tires P245/75R16 front
and P255/70R16 rear will this have any effect on truck ?
Oct 28, 2008 at 2:24 AM
DLOBI
  • 125 POSTS
It could. It is more important to have same sized tires on a 4 wheel drive than on a 2 wheel drive. If you are in 4x4 you need the wheels to be turning at the same speed as to not be causing damage to any drivetrain components. A 245/75 and a 255/70 series tire are pretty close in outside diameter but I would replace two of them. A larger outside diameter tire will be spinning at a slower rpm than the smaller diameter tire to travel the same distance.
Oct 28, 2008 at 2:29 AM
