When I turn on my temperature control switch I get a "flapping" or "clapping" noise from behind the dash-in the area of the blower, control, air flow switch. It is a steady noise, which sometimes goes away after the a/c and blower are turned on but not always.
A friend says it is a opening, broken, on a fan or wheel.
Any idea on what the problem is and to repair will it require pulling the dash to get to it? Not an easy or cheap job.
Thanks!
Thanks!
Aug 13, 2010 at 2:11 AM
