2003 Ford Explorer soleniod control valve B
155,000 MILES • 6 CYL • 4WD • AUTOMATIC
JDHARRIS68
the odbll told me that the solenoid control valve B is my problem. The transmission stalls from 1st to 2nd gear. Is the solenoid control valve in the tranny or on the outside of the tranny. Thank You
Mar 17, 2009 at 8:02 AM
MERLIN2021
  • 17,250 POSTS
There are five SSB codes possible from P0731 to P0735 which one did you get?
Mar 17, 2009 at 8:11 AM
JDHARRIS68
I recieved the odbll code of PO775
Mar 17, 2009 at 8:22 AM
MERLIN2021
  • 17,250 POSTS
I show a P0755, no 775 will need to look into it further.
Mar 17, 2009 at 8:26 AM
MERLIN2021
  • 17,250 POSTS
P0775 is for the pressure solinoids, not shift solinoids...You either have a weak pump, clogged screen, electrical failure of the wiring or solinoids...to test them you need an NGS tester for Fords, this can command different pressure for testing...I will send it to you, but may not help...
Mar 17, 2009 at 8:32 AM
JDHARRIS68
Ok Mr Merlin 2120, I gotta go p/u my daughter and wife and I will double check the code and make sure as soon as I get back let you know. I really appreciate what u r doing because ford acted as if they had no clue. Although, I do feel a little silly as I am a diesel mechanic.
Mar 17, 2009 at 8:33 AM
