2003 Ford Explorer shocks and struts
12,500 MILES • 6 CYL • 4WD • AUTOMATIC
MALBERTS5
I took my 2003 Explorer in with 125,000 miles. The suspension has been squeaking when I go over bumps, but only when it's cold. The mechanics first told me (over the phone) that there were shocks and struts, but then when I took it in, they called to let me know that there were only struts (which were more expensive) and that I needed to have all 4 replaced. This is an expensive procedure, so I just want to make sure that I'm not being taken through the ringer because I'm female. Could this be right?
Dec 15, 2009 at 6:22 AM
  • 110,251 POSTS
Your vehicle does have 4 struts. However, if the noise only happens when it is cold, I would think it is more likely a sway bar bushing or other rubber bushing. Have they checked all of that?
Dec 18, 2009 at 5:37 PM
