2003 Ford Explorer shakes when braking
86,000 MILES • 6 CYL • 4WD • AUTOMATIC
YANGKIE
I have a 2003 Ford Explorer, when I brake it shakes. The rotors were worped so I replaced the brakes and rotors but it continues to shake when I brake. I disassembled it and notice the new brake pads were only worned on the outer edges. I've already tried tourching the lug nuts. Do I need to sand down my brake pads so it's even?
Jun 9, 2009 at 3:24 PM
BLACKOP555
  • 10,386 POSTS
when you replaced the rotors the pad should be replaced too.
make sure the caliper mounts arnt bent and are properly tightned down to the knuckle.
next step would be make sure the wheels are properly torqued on. if that isnt it you should have a on vehicle brake lathe performed. that way it takes count of the runout with the car. much better then off vehicle. try new pads also.
have you checked rear brakes? drive fast and put on the rear brakes via the ebrake-parking brake. if vehicle vibrates problems in the rear.
Jun 25, 2009 at 4:36 AM
