removing rear brake rotors
DDCUTTY
4 cyl All Wheel Drive Automatic
I was wondering if there is a trick to remove the rear brake rotors on my explorer. Thanks
Sep 20, 2008 at 12:36 PM
BLACKOP555
  • 10,386 POSTS
Hello, This guide will give you an idea on how to do the job https://www.2carpros.com/articles/how-to-replace-rear-brake-pads-and-rotors This video will show you how to remove the stuck brake rotor https://youtu.be/UV0kfP17Co0
https://images.2carpros.com/forum/automotive_pictures/66751_2_1.jpg
Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed. Cheers
Sep 20, 2008 at 2:59 PM
