2003 Ford Explorer Rear Brake Rotors
58,000 MILES • 6 CYL • 4WD • AUTOMATIC
RJALLEN126
How do you get the rear brake rotors off? I have taken the the pads and caliper off, and removed the center nut that holds the rotor on the splined shaft. Used penatrating oil on the shaft spline, and tapped on the rotor hub. The rotor still will not budge.
Sep 25, 2008 at 5:04 AM
MERLIN2021
  • 17,250 POSTS
First that axle nut DOES NOT come off to remove a rotor! Reinstall it! If the rotor is stuck, remove the adjuster plug in back and back off the parking brake adjuster. Use a hammer if the rotor is still stuck, these are slip on and off rotors! Make sure you torque that axle nut so you dont cause any damage to the bearing.
Sep 25, 2008 at 10:18 AM
