2003 Ford Explorer possible burnt valve (no compression)
80,000 MILES • 6 CYL • 4WD • AUTOMATIC
STEVE400
Check engine light went on. OBD Codes said 2 cyl with not enough spark. Replaced plugs, no help. Replaced
Coil. Check engine Light went out, performance still subpar. Tested compression - one cylinder with no compression now.
Replace engine? Or will a valve job solve the problem?
What is your guess as to least cost solution?
Thanks.
Jan 2, 2010 at 9:44 AM
  • 75,988 POSTS
Dunno about the costs it varies with locality-I'll go for the Valve Job the engine is still young at heart, now if you have the $$$$$$$ go for the long block-
Jan 2, 2010 at 11:00 AM
