2003 Ford Explorer Please help making griding noise from re
133,800 MILES • 6 CYL • 2WD • AUTOMATIC
POCOLACHRISTIAN
  • 62 POSTS
I just got a new rear end put on my 03 explorer. Now when i'm driving usually around 35-50mph and let of gas and it's coasting slower i hear a grinding noise coming from rear end. Could that be tire noise or something more. Please help. Thank You.
Mar 20, 2010 at 12:24 AM
TOOOMANYTOYS
  • 513 POSTS
Is the differential brand new or used? Check differential fluid level. Also raise the vehicle in rear and spin the wheels by hand to see if you can dertermine where the noise is coming from.
Mar 20, 2010 at 12:31 AM
POCOLACHRISTIAN
  • 62 POSTS
I don't know if it's used or new but could it be that they used the wrong fluid. Also could it be tire noise that's what they told me after they fixed it that they heard tire noise. also someone told me hub assembly i have no idea. Thank You
Mar 20, 2010 at 8:31 AM
TOOOMANYTOYS
  • 513 POSTS
If it was the tires it would be more like a humming noise. You could try rotating the tires to see if the noise goes away. You may also want to purcahse an automotive stethoscope. With vehicle supported properly and front tires chaulked put the vehicle in drive and use the stethoscope to pinpoint souce of noise. This procedure can be dangerous and you may want to seek the help of an automotive service facility. Thanks for the vote. Hope this helps
Mar 21, 2010 at 11:34 AM
