2003 Ford Explorer play in pinion
2003 FORD EXPLORER
135,000 MILES • 6 CYL • 2WD • AUTOMATIC
POCOLACHRISTIAN
  • 62 POSTS
I just got the pinion replaced and now noticed that it make a grinding type noise when deaccelerating. I crawled under vehicle and grabbed where drive flange connects to pinion flange and turned it back and forth about half inch each way. Is that supposed to do that or is that normal and any ideas on the noise. Thank You
Apr 25, 2010 at 1:02 PM
  • 110,241 POSTS
It's normal. However, the noise isn't. I would have that rechecked. They may need to readjust the backlash.
Apr 26, 2010 at 12:49 AM
POCOLACHRISTIAN
  • 62 POSTS
Hi, I was wondering how you do that. Is it a major job or just somehting small to do. Thank You
Apr 26, 2010 at 9:38 AM
  • 110,241 POSTS
It requires a skilled mechanic that knows what he is doing.
Apr 26, 2010 at 3:42 PM
