My vehicle seems to be making like a nose dive sound when I am slowing down to make a turn. What is causing for this noise to happen?
Jun 5, 2009 at 3:02 PM
MIKE H R
MEMBER
It could be a number of things from springs, a ball joint going bad, shocks,or brakes grabing. I would have the front end checked to see if they can find out where the problem is. It might be a simple fix after you find out what is doing it.
