2003 Ford Explorer It doesn't stay running
120,000 MILES • 6 CYL • 2WD • AUTOMATIC
CARINGSMILE
I just wanted to know could it be that would keep the car from staying running. Already fixs the manifold and the cataylic converter, that is what was wrong the first time. Then after got it fix. It would start up. So then I fix water pump, sprak plugs and the master air flow sensor. Then it would start up, but don't stay running now. What else could it supposely be.
Sep 1, 2009 at 5:39 AM
  • 110,251 POSTS
Have you checked fuel pump pressure?
Sep 1, 2009 at 6:30 AM
