2003 Ford Explorer INSTRUMENT PANEL GOING CRAZY
88,000 MILES • 6 CYL • 4WD • AUTOMATIC
BIGMIC911
WITH IN THE LAST MONTH OR SO WITHOUT WARNING WHILE DRIVING MY RADIO WILL SHUT OFF AND THE INSTUMENT PAEL WILL GO HAYWIRE FOR 4-5 SECONDS AND THEN RETURN TO NORMAL. I HAVE TRIED TO SEE IF THERE IS A PATTERN TO IT BUT SOMETIMES I WILL BE GOING 30 MPH AND IT HAPPENS OTHER TIMES I CAN BE DOING 65 MPH AND IT HAPPENS AND THEN SOMETIMES IT WILL NOT HAPPEN FOR DAYS AT A TIME. ANY IDEA WHAT THE PROBLEM MAYBE
Aug 24, 2008 at 3:20 PM
TERPUG
I have the same issue. Ford has replaced it 3 times. Each replacement has failed at different intervals for 4 days to 9 months to this time over a year. Now it is not covered under warranty.
Sep 5, 2008 at 9:51 AM
