2003 Ford Explorer Headlight replacement
2003 FORD EXPLORER
DGRETKA
Electrical problem
2003 Ford Explorer 6 cyl Four Wheel Drive Automatic
How is the assembly removed to access the bulb?
Jan 4, 2010 at 4:32 AM
  • 110,240 POSTS
You should be able to access if from under the hood, behind the headlight assembly. Check to see if you can find the light socket. It should unscrew out.
NOTE: Don't touch the glass part of the new bulb. The oils from your skin will cause the bulb to create a hot spot and it will burn out faster.
LEt me know if you find the socket.
Jan 6, 2010 at 2:36 PM
