2003 Ford Explorer gauge cluster going crazy
EVANSRYAN89
Electrical problem
2003 Ford Explorer 6 cyl All Wheel Drive Automatic
ok i was driving down the road when all the gauges started going crazy motor dogged down then all the check engine lights came on, i shut the car off and started it again and it was fine and this is the second time it has happened. i have know clue what the problem is hope you can help.
Jan 3, 2010 at 10:40 AM
  • 110,251 POSTS
Has the check engine light ever come on? Have you had the body control module tested?
Jan 7, 2010 at 12:07 AM
EVANSRYAN89
i finally got it to the shop and the alternator was over charging the car causing it to go crazy. thanks for replying with help anyways
Jan 7, 2010 at 8:19 AM
