2003 Ford Explorer Front End Howling
57,000 MILES • 6 CYL • AWD • AUTOMATIC
ROMAN17
I have a 2003 Ford Explorer XLT 4.0 FF with 57k on the clock. I have began to notice that when cruising, or when I am not on the throttle and free wheeling, the truck makes a howling noise, somewhat rythimic (rotational i believe). I have checked my front brakes and cleaned them, this has done nothing but dirty up a set of clothes. I have read tat it can be many problems, but i do not want to go and spend money without knowing what it is. Also, when the truck has been driven a bit, there seems to be a thud, again rythmic in nature. I have read that the rear end may be a problem, but i feel it to be the front... Bearings? Fluid issues? Also note, the tires on the front are dissimalar by the following numbers (245 65 R17, 105S, M+S and 245 65 R17, 105S, M+S, DT) Please help!
Oct 3, 2008 at 3:18 AM
MERLIN2021
  • 17,250 POSTS
Have you checked the tires for minor cupping? if the tire tread is uneven it will cause the problem or you describing.
Oct 3, 2008 at 8:50 AM
