2003 Ford Explorer Ford Explorer Sport brake repair
86,000 MILES • 6 CYL • 2WD • AUTOMATIC
JLDEVITT
When having the rotors changed in a rear wheel drive vehicle, do all 4 rotors get chaged and all pads or just 2? front or back? I'm also trying to figure out the right questions to ask the brake shops before I go there so I don't get over charged.
Jan 16, 2009 at 1:40 AM
DAVE H
  • 13,383 POSTS
if you replace one side ie. left rear .. you should also replace right rear at same time ... if you replace front left .. then replace front right at the same time .. so there is no imbalance .. front and rear can be changed independantly of each other !!
Jan 16, 2009 at 1:47 AM
