2003 Ford Explorer excelerator
10,000 MILES • 6 CYL • 2WD • AUTOMATIC
B.DURAN
car does not pump gas when you push excelerator and will not turn on
Apr 24, 2010 at 3:49 AM
  • 110,248 POSTS
Are you saying that you checked fuel pump pressure and there is none? IF so the pump needs checked or replaced. I would first check to make sure it is getting power. If it is, then replace it.
If you haven't checked pressure, here is a how to for checking:
https://www.2carpros.com/car_repair_video/test_fuel_injection_pressure.htm
Apr 24, 2010 at 2:16 PM
