2003 Ford Explorer ENGINE WAS REPLACE AC BLOWING HOT AIR
66,000 MILES • 6 CYL • 2WD • AUTOMATIC
GETTHE FACTS
HAD A USED ENGINE PUT IN 2003 FORD EXLPORER. I TURNED ON THE AC IT JUST BLOWS OUT HOT AIR. MY QUESTION IS DOES THE HOT AIR BLOWING OUT HAVE ANYTHING TO DO WITH THE REPLACING OF THE ENGINE. I SEE THAT MY WARRANTY SAID VOID IF OVERHEATING OCCURS. THANKS VERY MUCH FOR A ANSWER
Apr 14, 2010 at 10:42 AM
DAVE H
  • 13,383 POSTS
check/replace the freon gas for the A/C .. it may have been lost when engine was swapped !
Apr 15, 2010 at 7:49 AM
