2003 Ford Explorer DOORS
MACKARD
Electrical problem
2003 Ford Explorer 6 cyl Four Wheel Drive Automatic
MY DOOR AJAR LIGHT REMAINS ON EVEN WHEN ALL DOORS ARE CLOSED; ALSO INTERIOR LIGHTS COME ON RANDOMLY
Jan 14, 2010 at 10:07 AM
  • 110,251 POSTS
Chances are one of the switches on the door is bad. You actually have to remove them each to determine which is bad. If they all check good, then I would have the body control module tested.
Jan 14, 2010 at 12:11 PM
BMRFIXIT
  • 19,053 POSTS
Need to use a scanner tool and check for B codes and check data
an OBDII reader will NOT access the data that you need
most common is driver door switch
use WD40 spray switch (door latch )
open and shut door few times
also you can do the same on all doors
good luck
Jan 14, 2010 at 12:25 PM
