2003 Ford Explorer Door Ajar
KBAZ73
  • 2003 FORD EXPLORER
  • 6 CYL
  • 4WD
  • 73,000 MILES
My DOOR AJAR light stays on. I have checked all doors, nothing left open. It leaves my interior lights on, as well as, the lights under side mirrors. I am not sure if this is a sensor issue?
Monday, December 15th, 2008 AT 6:11 PM
DAVE H
  • 13,384 POSTS
Check the switch and wiring on door pillar where door hinges are located?
Monday, December 15th, 2008 AT 6:15 PM
BMRFIXIT
  • 19,053 POSTS
USE WD40 and spray door latch
door switch located inside on the side of the door latch and known to get stuck
most of the time if sprayed with WD40 will loosen up and work again
spray the latch close and open the door few times
spray all door latches
or have it scanned as it will show which switch is open
good luck
Monday, December 15th, 2008 AT 7:32 PM
