2003 Ford Explorer Differential Noise
180,000 MILES • V8 • 4WD • AUTOMATIC
SANAMALY
I have a ford explorer limited, year 2003. It is driven 180,000 km. At around 174,000km i started hearing this noise from the front of the truck under the driver seat. The noise would come at around the 60kmh speed and increase as the speed increases. I took it to a mechanic and he said the wheel bearing needs to be replaced. I got the wheel bearing replaced but the noice was still there. Now i got it checked from another mechanic and he tells me that theres a problem with the differential. Can you please tell me what the problem could be and how i can get it fixed? Some suggest to get a new and revised ring & pinion gearset. Can you tell me what the best solution will be to get rid of the noice?
May 22, 2008 at 7:11 AM
MERLIN2021
  • 17,250 POSTS
Technical Service Bulliten: 4X4 only, revised driveshaft for droning noise at 55-75 MPH. Ref number:5-16-4 Call dealer and see if yours is on the list...
May 22, 2008 at 7:49 AM
