2003 Ford Explorer cylinders 1,2,& 3 are fouling
2003 FORD EXPLORER
104,000 MILES • 6 CYL • 2WD • AUTOMATIC
JAKESSPORT
  • 6 POSTS
what could cause bank one to run rich and foul out the plugs. I have changed both o2 sensors on bank one, put in new plugs and wires. The truck stutters very bad when I put it on drive and have my foot on the brake.
Jan 14, 2010 at 3:43 AM
  • 110,244 POSTS
I want you to check fuel pressure, and fuel pressure drop off. I would like to know if you have fuel injectors that are sticking.
Here is a how to. Remember, pay special attention to the fuel pressure drop off. That is when you shut the key. THe pump stops, but the system should maintain pressure for some time.
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Let me know what you find.
Jan 14, 2010 at 12:27 PM
JAKESSPORT
  • 6 POSTS
I have just checked the fuel pressure, and it has remained the same, it hasn't dropped off....what should I try next resting at 62 lbs of pressure
Jan 21, 2010 at 4:36 AM
  • 110,244 POSTS
Okay, that tells us there is no leak at the injectors or other places. I have to ask, does the 2003 have one coil or one for each cylender. Sorry, 7 years ago I knew this but I'm getting old. (LOL)
Jan 21, 2010 at 11:16 AM
JAKESSPORT
  • 6 POSTS
It has one coilpack for all six cylinders
Jan 21, 2010 at 12:28 PM
  • 110,244 POSTS
Have you checked the oxygen sensor?
Jan 21, 2010 at 2:02 PM
JAKESSPORT
  • 6 POSTS
I replaced both of them on bank one, and there was no change
Jan 26, 2010 at 3:59 AM
  • 110,244 POSTS
The only other thing I can think of is the PCM. For only one side to be running rich, the injectors must be firing more fuel than the other bank.
Jan 26, 2010 at 5:34 AM
JAKESSPORT
  • 6 POSTS
Is there any way I can test the pcm. Where would you suggest finding one? Does the PCM need to be flashed to my VIN
Jan 30, 2010 at 11:38 AM
  • 110,244 POSTS
You will need special test equipment to check that. As far as getting one, I would suggest a salvage yard. However, make sure it has the exact same part number.
Jan 30, 2010 at 3:59 PM
SCOTTY DEE
  • 592 POSTS
Before you go to the trouble of replacing the PCM, I see no mention of retrieving any present trouble codes. Are there any codes present?
Jan 31, 2010 at 1:50 AM
JAKESSPORT
  • 6 POSTS
I got a run tested pcm from a salvage yard, it has the same numbers exactly, but when i put it in the car would not start.
Mar 31, 2010 at 6:25 AM
