2003 Ford Explorer Can't adjust heater temperature.
69,000 MILES • 6 CYL • 4WD • AUTOMATIC
SALTLAKE
When I turn the temperature control, it continues to blow hot air even when dialed all the way to cold. I recently had some work done on it because when you selected the 'floor' setting it stayed on defrost. That seems to be ok but now I can't adjust the temperature. Any thoughts? Thanks!
Feb 18, 2009 at 12:43 PM
DAVE H
  • 13,383 POSTS
sounds like you have a fault on the blend door .. this should set a DTC .. diagnostic trouble code .. have the vehicles PCM (computer) read for fault codes to verify where the fault lies !
Feb 18, 2009 at 12:48 PM
