2003 Ford Explorer Brake Light
186,000 MILES • V8 • 2WD • AUTOMATIC
LONGBALL
I changed the left rear brake and turn signal light. After doing so, the light still does not work. I installed the light in the right side to see if it was the light itself, but the light worked. What could cause this issue?
Oct 31, 2009 at 6:29 AM
MERLIN2021
  • 17,250 POSTS
Remove the bulb, use a test light on the contacts of the soket to determine if power is getting the the socket, if it is, you may find one of the contacts may have been bent, straighten them out...if power is Not getting back there, test wires with the light until it lights, then fix the short at that point where the test light lights up.
Oct 31, 2009 at 6:35 AM
