2003 Ford Explorer Battery Cable change
123,000 MILES • 6 CYL • 4WD • AUTOMATIC
BDCMA103
I am changing the complete battery wiring harness. I have the old one out. I can not figure out how to get the wire to the alternator from the bottom sode of the engine. Do I need to remove some pulleys or something? It it a 4.0L V6. Thanks, Aaron
Sep 23, 2010 at 8:06 AM
HMAC300
  • 48,601 POSTS
if you got the old one out without taking any pulleys off then you should be able to reverse the procedure and not take anything else off as well......
Sep 23, 2010 at 1:18 PM
BDCMA103
[quote:73034b9beb="hmac300"]if you got the old one out without taking any pulleys off then you should be able to reverse the procedure and not take anything else off as well......[/quote:73034b9beb]
Sorry should have added this part at first.....I had to cut off the two conections to pull the origonal wire out of this spot.
Thanks!
Sep 23, 2010 at 2:13 PM
HMAC300
  • 48,601 POSTS
if you cut the old cable then you may have to take a pulley off, but if you take teh belt off there may be enoguh room to squeeze the new cable through......
Sep 24, 2010 at 2:27 AM
