The backup sensor defaults to off the second I put the vehicle in reverse. I put it back in park and am able to turn the dashboard switch to on but it continues to turn off instantly as I move the shifter through reverse. I've cleaned the area and looked for obvious problems but all appears to be normal.
Thank you
Thank you
Mar 7, 2008 at 1:33 PM
