2003 Ford Explorer Alternator Replacement
115,000 MILES • 6 CYL • 4WD • AUTOMATIC
ABRISCHLER
How do I replace the alternator on a 2003 Ford Explorer?
Apr 5, 2009 at 2:36 PM
BLUELIGHTNIN6
  • 16,542 POSTS
REMOVAL:
Remove or disconnect the following:
Negative battery cable
Air cleaner outlet tube
Accessory drive belt
Electrical connectors
Wiring harness-to-alternator pin-type retainer
Stud bolt, the bolts and the alternator
INSTALLATION:
Installation is the reverse of the removal procedure.
Mounting bolt tightening torques 35 ft. lbs. (47 Nm).
Thanks for using 2CarPros.com!
Apr 5, 2009 at 4:33 PM
