2003 Ford Explorer Alternator
FAMPRICEY
Electrical problem
2003 Ford Explorer 6 cyl
Whilst driving all guages and lights turned off, voltage dropped to zero and the the engine eventually died as we coasted to a stop.
Now,my engine will not run unless it is plugged into a charger, once charger is turned off, engine dies.
The battery saver relay ticks, it has been replaced bu still ticks, all battery cables and terminals are clean and secure and the starter relay has been tested and is ok.
Is this the fault of the alternator?
Oct 6, 2010 at 8:23 AM
  • 75,988 POSTS
Start by having the alternator load tested and go from there
Oct 6, 2010 at 11:20 AM
