2003 Ford Explorer air temp control wont switch to hot air
BIKERLOB
  • 2003 FORD EXPLORER
  • 6 CYL
  • AWD
  • 110,000 MILES
110000
Friday, September 10th, 2010 AT 11:27 AM
WRENCHTECH
  • 20,761 POSTS
The heat in that vehicle is controlled by a blend door that regulates heated air flow. It is operated by an electric motor/actuator. The problem can be that the actuator is stripped or inoperative or the door itself could be damaged. This is what needs to be determined by examining the actuator and see if it is responding to heat change commands or not.
Friday, September 10th, 2010 AT 11:37 AM
