2003 Ford Explorer air not blowing hard like it should
138,000 MILES • 6 CYL • 2WD • AUTOMATIC
POCOLACHRISTIAN
  • 62 POSTS
My 03 explorer's air is on high but not blowing very hard. It sounds like it is from under the passenger dash but not coming out of vents very hard. Also not very cold sometimes it gets cold and then gets warm goes back and forth. Please help.
Jun 4, 2010 at 5:32 PM
  • 110,248 POSTS
First, it sounds like there is a vacuum leak to the HVAC. The vent doors are actuated by vacuum. If there is a leak, it is hard to tell where the air will come out. Check under the dash and the hood for leaks. With the engine on, you may get lucky and hear a hissing sound from the leak.
Let me know what you find.
Jun 9, 2010 at 1:11 AM
POCOLACHRISTIAN
  • 62 POSTS
I checked under dash i couldn't reallly tell if it was leaking but i took out glove box door and i could feel cold air coming out from under there a little. I really don't know what to look for but i know it's not blowing very hard at all. I was just wondering is this normal for explorers. Thank you.
Jun 14, 2010 at 12:41 PM
  • 110,248 POSTS
First, thank you for the positive feed back. Second, the problem really isn't normal for this vehicle. Have you checked under the hood to see if there are any leaks there?
Jun 16, 2010 at 3:01 PM
POCOLACHRISTIAN
  • 62 POSTS
Hey i noticed something. When i turn it on max air or just the dash vents i can still feel cold air coming out of the floor vents. Could that be why it's not blowing hard.
Jun 17, 2010 at 12:25 AM
  • 110,248 POSTS
It still sounds like a vacuum problem. And yes, if part of the air flow is going to the floor, that would be a cause.
Jun 18, 2010 at 4:49 PM
