2003 Ford Explorer abs light on
100,000 MILES • 6 CYL • 4WD • AUTOMATIC
LATOYIA YOUNG
abs light on grinding noise the brakes not stiff going to floor
Mar 13, 2010 at 12:37 AM
MERLIN2021
  • 17,250 POSTS
If you are hearing grinding noises, if you know how to inspect brakes, do that, if not tow it to a qualified repair shop. GRINDING mean there is no more brake lining material left on the pads. you are nor riding metal on metal, and worn so far down that the caliper is probably loosing brake fluid as well, TOW to a shop!
Mar 13, 2010 at 1:04 AM
