2003 Ford Explorer ABS Light on
115,000 MILES • 6 CYL • AWD • AUTOMATIC
PMARKER
I have an ABS Light on. I had an ABS diagnostic tool read the error and it said something wrong with the wheel speed sensor on the right side. I found on the internet that a wheel hub going bad could also cause this.I replaced the HUB that also came with a new wheel speed sensor. After replacing the wheel hub and wheel speed sensore the ABS Light is still on. What should I check next.
Aug 21, 2009 at 12:10 PM
  • 110,248 POSTS
Was the computer reset? If so, check the wiring and connection to the sensor.
Sep 10, 2009 at 4:24 AM
