2003 Ford Explorer abs ,battery, and airbag light is on the
80,000 MILES • 6 CYL • 2WD • AUTOMATIC
DELAMORA79
while driving 1st abs light comes on, then 10 seconds later the battery light comes on then the dash light goest out and all gages down then engine starts loosing power then turns off the only light on inside yellow airbag ligh then goest off... after few hours the explorer starts find again this is the 2nd time it happends
Sep 18, 2010 at 5:21 PM
KHLOW2008
  • 41,812 POSTS
Hi DELAMORA79,
Thank you for the donation.
Symptoms indicates a power supply interruption or charging issue.
A power supply interruption could be due to a failing ignition switch. While engine is running, when power from the ignition switch is cut off, the dash indicator lights might come on momentarily and the goes away.
I would suggest checking the ignition switch. While engine is running, check the ignition, it should not be hot to the touch. A hot ignition switch indicates the internal contacts are insufficiently secure and can cause the contacts to fail over prolonged driving.
Sep 18, 2010 at 6:08 PM
