I am losing power to all electrical guages and the engine. My car starts fine, runs for awhile and then the gauges drop off line, check battery light comes on and car finaly stops. It sound like the electrical is cycling on and off when this is happening.
My battery is good because when I let the car sit for awhile it will start and everything works fine for about 10 minutes.
It happened last night and that is not good when it is night time. I tried to start it right away but it only click/click/click. But when I put a charger on to check the battery it showed good and started right up on boost/start with out having to charge.
Could this be a ground problem or maybe whatever.
I have no idea. Please help.
mxbrand
mxbrand
Jan 10, 2010 at 5:27 AM
