2003 Ford Explorer
90,000 MILES • 6 CYL • 2WD • AUTOMATIC
LILSOPHIA
hello
the a/c is not blowing cold air. i checked the feron and it was low so i had added ferom but it still did not work. a few weeks later the feron seemed to be low. which is wierd because i had not used the a/c . could there be a link? is this a huge problem or can i fix myself?
thank you
Jun 25, 2008 at 8:19 AM
BMRFIXIT
  • 19,053 POSTS
Freon 134A does not go low if you use the AC or not
it should be a sealed unit
you need to check for leak
may I suggest having a qualified tech take a look at it as they have to add dye to the system and check for leaks
good luck
Jun 25, 2008 at 12:44 PM
