2003 E XTL Dashboard Warning
MRJOHNDANIELS
Ford Explorer 2003 XTL
36,206miles
The "4x4 High" and "4x4 Low" lights flash 3 times every minuet or so. The "4x4 Auto" is currently selected.
There are no noises, or sluggish steering. I have searched everywhere to find a translations for these warning lights. I really don't want to go to a garage to find out $400 later that all I needed to do was change some fluids. Please help.
Mar 5, 2007 at 3:39 AM
TAURUSWHEEL
  • 718 POSTS
i'm not familiar with Explorers per se, but sounds like it's outputting some type of code, someone else on here knows more.
Mar 5, 2007 at 7:36 AM
MRJOHNDANIELS
Someone said its a code for the Speed Sensor is bad. And that the auto 4x4 is not working which means its only useing 2 wheels. But i dont know how to fix this problem or even if it is the problem... so any more input from people might help. thanks in advance.
Mar 5, 2007 at 11:42 AM
TAURUSWHEEL
  • 718 POSTS
I don't believe the dealer would charge 400 bucks to diagnose, at least pull whatever code or codes are flashing the light... stay away from guesses as to what it is, you'll either hit the one-in-a-million correct one or spend needless dollars on the others.. try taking it to a parts store and have them scan your system, most all do it for free, see if they can come up with anything,, if so get the code numbers
Mar 5, 2007 at 3:21 PM
