2002 Ford Explorer won't start
VAIPUNA
Engine Mechanical problem
2002 Ford Explorer 6 cyl Two Wheel Drive Automatic
been parked for a month. worked fine before.
turns over but won't fire. strong battery.
never had this problem.
any ideas?
Nov 22, 2009 at 4:01 AM
  • 75,988 POSTS
Do below:
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor /distributor pick-up coil, ignition control module, ECM,Ignitor camshaft and crankshaft sensors- Note: If it doesn't apply disregard it
Nov 22, 2009 at 4:31 AM
