2002 Ford Explorer Wont start.
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Have the no-crank condition diagnosed first, including starter-command and loaded power/ground checks. Tell the technician about the impact and fan noise.
Guidance references and applicability
Source: This question and its visible discussion. The roadmap distinguishes the original owner's reports from other participants' experiences; proposed follow-up is editorial guidance, not a confirmed diagnosis. Fluke: Diagnosing voltage drops https://www.fluke.com/en/learn/blog/automotive/electrical-automotive-troubleshooting General support for loaded circuit testing; use matching vehicle specifications.
This switch is tripped by hitting something hard (like a curb / light pole, etc...) or something hitting u hard...the net-net the switch is normally in a hidden area, such as under the pax upper area on the side below the glove box...floorboard area or in Expeditions and others located in the back most part of the cargo space in the jack storage areas, etc...
Check the user manual for the exact location to re-set the switch manually
Discussion summary
After bumping a curb, the owner of a 2002 Explorer V8 reported unusual fan noise and then a no-crank condition. The battery reportedly passed a test. Replies suggested starter wiring, a relay and a fuel shutoff switch.
Reported outcome: No repair or successful restart was reported.
No starter-circuit readings were provided. The fuel-switch suggestion did not establish the cause of the reported failure to crank.
