2002 Ford Explorer window will not raise
JCLHOGAN
2002 Ford Explorer Automatic
The front passenger side window, when lowered, didn't raise back up. You can hear the motor running to raise it. I was trying to find a diagram of the door to try to repair it.
Dec 18, 2008 at 1:12 PM
BMRFIXIT
  • 19,053 POSTS
Sounds as u need a widow regulator
remove speaker
remove switch
remove door panel
remove water shield
check motor and regulator
Dec 18, 2008 at 1:21 PM
