2002 Ford Explorer window doesn`t go up .
114,966 MILES • 6 CYL • 2WD • AUTOMATIC
CONCERN39
the window by the drivers side doesn`t go up but the rest of the windows still working.. .i dont know what was wrong... please give me some idea thank you
Feb 12, 2009 at 3:29 AM
  • 110,248 POSTS
Hi:
You need to remove the door panel to see if the motor is getting power. If it is, the motor is bad. If there is no power, work back to the switch to see it there is power to it and out. The switch could be bad too.
let me know what you find.
Feb 13, 2009 at 12:45 PM
