2002 Ford Explorer Window
2002 FORD EXPLORER
90,000 MILES • 6 CYL • 4WD • AUTOMATIC
STEVEKATIE
My driver's window goes down sometimes, and sometimes it doesn't. No problems with any other windows. Is it the switch or the motor? How expensive is it to fix. I am not a mechanic.
Aug 10, 2010 at 5:29 AM
  • 110,241 POSTS
It could be either the motor or the switch. You need to check if the motor is getting power when it doesn't work. If it has power, the motor is bad. If there is no power, then the switch is most likely the problem.
A new window motor is around 50.00 at a parts store and allow about an hour to replace it.
Aug 10, 2010 at 4:10 PM
